Mining settings
18. června 2022 17:33
    Kryptex Settings
    Misc -> Show miner windows
kryptex_t-rex.exeT-rex miner
kryptex_gminer.exeGminer
kryptex_xmrig.exeXMRig miner
kryptex_nbminer.exeNBMiner
kryptex_lolMiner.exelolminer
kryptex_rigel.exeRigel miner
Miner and its version
Have find what you need? Then, try to put the new settings in Kryptex!
  1. Open the Kryptex settings.
    Miner's settings
‼Important
There are no random characters in settings!
  • All commands are written in a string, separated from each other according to the developer's requirements. Usually it's a "space".
  • The commands’ values, overclocking multiple GPUs, e.g., are separated by the comma, space button, or semicolon.
  • The command starts with the symbol "-" or "--"
If Kryptex does not start mining after entering the setting, instead of profitability it says "Starting computations…"; the miner window is constantly blinking — you made a mistake in the settings’ line.
Kryptex can't start the computations
An extra symbol, accidentally pressed "space" or "enter" key before, in the middle, or at the end of the settings’ line — an awkward error that will not allow the miner to start.
🤔Can I use any commands for the miners?
Not really. Kryptex sets the primary miners’ commands by itself (pool address, wallet, password). In addition, there are a couple of unavailable commands:
  • Kryptex sets the list of mining devices, so the -device command is unavailable for T-Rex.
  • Disabled command watchdog because Kryptex itself performs its functions.
  • Kryptex sets remote monitoring port 12000 (if multiple miners are running — 12001, 12002...). You can't change them, but you can usually see how your miner works at http://127.0.0.1:12000/
  • You cannot use commands that are unsuitable for your graphics card.
  • Kryptex automatically applies -rxboost 1 command for GPUs AMD RX 4xx/5xx for Phoenix miner, you can’t change it.
The rest of the commands you can use.
Too complicated?
Tell us what parameters you want to apply and what miner you wish to use. We will be happy to help!
Contact as at the support page, PM us at Telegram, or as for help on Reddit.
Registrovat
