Where is Kryptex installed?
    2023年9月4日 18:32
  Kryptex is installed just like any other program.
By default, Kryptex is placed in two locations:
- C:\Program Files\Kryptex— This is where the Kryptex App locates itself.
- C:\Users\<username>\AppData\Roaming\Kryptex— This is where you'll find miners and Kryptex system files. Remember to replace- <username>with your Windows username.
If you are unsure about your username, use the generic path
%Appdata%\Kryptex.
The AppData folder is a hidden system folder in Windows. To access it, you must enable the display of hidden files and folders.
View hidden files and folders in Windows 10
- Open ”File Explorer” from the taskbar, or open any folder on your PC.
- Select ”View” and then select ”Options”.
- Select the ”View” tab and, in ”Advanced settings”, select ”Show hidden files, folders, and drives”, untick “Hide extensions for known file types”.
- Click “Apply” and then “OK”.
View hidden files and folders in Windows 11
- Open ”File Explorer” from the taskbar, or open any folder on your PC, and click the three dots on the top.
- Go to "Options".
- Choose "View".
- Select "Show hidden files, folders, and drives” and untick “Hide extensions for known file types”.
- Press “Apply” and ”ОК”.
