How to add Kryptex to BitDefender antivirus exclusion?
31 серпня 2023 р. 13:05
It's advisable not to include the entire folder, as this could prevent the antivirus from offering protection if a virus enters the miner folder. Instead, selectively add individual Kryptex files to the exclusions list rather than excluding entire folders.
Add Kryptex to BitDefender exclusion
  1. Select “Protection” from the navigation menu of the Bitdefender interface.
  2. On the "Antivirus" panel, click "Open".
  3. Then go to the "Settings" tab of the "Antivirus" panel and click "Manage exceptions".
  4. Then click the “Add Exception” button.
  5. Specify the paths for exclusion:
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners.7z
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners\kryptex_gminer\kryptex_gminer.exe
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners\kryptex_lolMiner\kryptex_lolMiner.exe
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners\kryptex_rigel\kryptex_rigel.exe
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners\kryptex_SRBMiner-MULTI\kryptex_SRBMiner-MULTI.exe
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners\kryptex_teamredminer\kryptex_teamredminer.exe
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners\kryptex_xmrig\kryptex_xmrig.exe
    • C:\Users\<username>\AppData\Roaming\Kryptex\miners\kryptex_onezerominer\kryptex_onezerominer.exe
      <username> — replace with your Windows user name.
  6. Turn on the switch next to ”Antivirus”. Click “Save”.
More details on the developer web page — https://www.bitdefender.com
Зареєструватися
