25 лютого 2025 р. 19:21
  1. Speed:
  2. Fees:
  3. Scalability:
An invoice looks like this:
  1. Select "Deposit" → "BTC".
    • Take the network fee into account when withdrawing. If you want to receive 0.0001 BTC and the fee is 0.000005 BTC, you should have at least 0.000105 BTC in your balance.
Invoice Entry Error
  4. Network Fee Consideration — take the network fee into account when withdrawing. If you want to receive 0.0001 BTC and the fee is 0.000005 BTC, you should have at least 0.000105 BTC in your balance.
Зареєструватися
