Jak możemy pomóc?
How to add Kryptex to BitDefender antivirus exclusion?
30 kwietnia 2026 14:37
Add Kryptex to BitDefender exclusion
  1. Select “Protection” from the navigation menu of the Bitdefender interface.
  2. On the "Antivirus" panel, click "Open".
  3. Then go to the "Settings" tab of the "Antivirus" panel and click "Manage exceptions".
  4. Then click the “Add Exception” button.
  5. Specify the paths for exclusion:
    • C:\Program Files\Kryptex
    • %AppData%\Kryptex
    • %AppData%\Kryptex\miners
  6. Turn on the switch next to ”Antivirus”. Click “Save”.
More details on the developer web page — https://www.bitdefender.com
Zarejestruj się
