Hello!👋🏻 How can we help?
Oct. 25, 2021, 2:47 p.m.
  • in Ethereum ETH;
  • in Litecoin LTC;
  • in USDT (BEP20, TRC20);
  • in USDC (Solana);
  • Volet.com payouts;
  • Bitrefill payouts.
Available connection options:
  • krxXXXXXX
  • krxXXXXXX/Worker1
  • krxXXXXXX.Worker
  • krxxxxxxx.Worker
  • KRXXXXXXX.Worker
  • john_miner@gmail.com/worker
How to connect?
Alternatively, you can use your email as the wallet address. However, not all miners support this format. If you choose to use your email, include the worker name by adding a slash. Example: miner@gmail.com/worker.
BTC+FB btc.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
FB fb.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
XEC xec.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
DGB dgb.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
BCH bch.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
LTC+DOGE+BEL+PEP ltc.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
ALPH alph.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
KAS kas.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
RXD rxd.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
ETC etc.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
ETHW ethw.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
OCTA octa.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
XMR xmr.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
ZEPH zeph.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
CFX cfx.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
XEL xel.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
IRON FISH iron.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
KLS kls.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
RVN rvn.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
CLORE clore.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
XNA xna.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
ERGO erg.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
NEXA nexa.kryptex.network:7777 username.Worker or miner@gmail.com/Woker x or nothing
Connect on Windows
Connect on HiveOS
Creating the Wallet
  4. Confirm the wallet setup.
Create the Flight Sheet
Connect on RaveOS
Creating the Wallet
Connection Settings
  1. Choose the coin type.
  7. Save your configs.
  3. Next, follow these steps:
    • Select the appropriate wallet for from the “Wallet” drop-down list.
Connect on ASIC/FPGA
❗Important Information
  3. Not all coins can be mined and exchanged for bitcoins. Check the table to see which coins available for automatic exchange.
🚑 Need Help?
Register
